20 Most Recent Panasonic KX-TG2357 Cordless Phone Questions & Answers
3answers
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
1/9/2017 3:54:07 AM • Panasonic... • Answered on Jan 09, 2017
Hello -need help with phone
Hi Nick,
There are no intensity adjustments I know of, and from my experience if the backlight is still working, but you get no display, it is either a bad display, or many times corrosion or a broken solder joint/component. I wish I could help you correct the problem with a few pushes of a button but not in this case. We do fix those models, you can check us out at www.cordlessrepair.com Thanks, CG
8/21/2015 7:13:11 AM • Panasonic... • Answered on Aug 21, 2015
Handset has become unregistered. Follow instructions to re-register and it says ERROR every time. What now?
start by unpowering everything and repowering. (remove/replace batteries also.) make sure u r in range of the BASE unit.
3/18/2015 1:42:06 PM • Panasonic... • Answered on Mar 18, 2015
Forwarding calls on Panasonic tx-tg2357
You can transfer a call between units, but you cannot forward to a different phone number. Page 48 of the manual details this: http://service.us.panasonic.com/OPERMANPDF/KXTG2357.PDF
3/18/2015 11:24:49 AM • Panasonic... • Answered on Mar 18, 2015
2answers
PHONE CS6629, HOW DO I ENTER LETTERS ON TO KEY PAD INSTEAD OF NUMBERSRS
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
4/14/2014 4:23:59 PM • Panasonic... • Answered on Apr 14, 2014
2answers
No link to base Panasonic KX-TG2357
Astoundingly, the KXTG2357 works only with the original handsets it came with! You cannot replace a handset by buying another one (same model, of course) and register it with the base. How ridiculous is that? It's like buying a lamp that works only with the bulb that came with it. Replacement bulbs won't work. Well, Panasonic is one company I won't be dealing with anymore!So, the solution is to get along with one less handset, or buy a new phone unit!
2/21/2014 2:21:36 PM • Panasonic... • Answered on Feb 21, 2014
Cs6629 how do i enter numbers on to key pad instead of numbers
12/30/2013 8:31:42 PM • Panasonic... • Answered on Dec 30, 2013
How to to retreive messages remotely
See the instructions beginning on page 62 of the manual: http://www.fixya.com/support/p123567-panasonic_kx_tg2357_cordless_phone/manual-7367
11/16/2013 6:16:16 AM • Panasonic... • Answered on Nov 16, 2013
Caller ID suddenly stopped working on our KX-TG5771 cordless sets
I have had similar problem the way I solved it .
Unplug all units from ac
Take out all batterys
unplug phone line.
Put back in reverse order .
They allways seem to work after.
I have noticed that if the phones are charged on the wrong stations they seemed to get confused for some reason.
Hope this helps
Doug
11/1/2013 8:02:28 PM • Panasonic... • Answered on Nov 01, 2013
0answers
Panasonic KX-TG2357 Cordless Phone Logo
116 questions posted
Top Panasonic Lands Phones Experts
Ekse
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
uniden dect3135
  • Lands Phones
