SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
SOURCE: sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1
Lift the power bar located above the ice maker storage tray.
Clean the Ice Machine
Reassemble the Ice Maker
SOURCE: The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
SOURCE: My sub zero 642 just starting making a humming
I know this sounds so stupid but I see this sort of thing at least once a week it's vibrating on cab. Or the main thing is a bolt came loss and when you open the door it aplies weight down and it will make the bolt or nut vibrate being a sub zero it could be the compresser on top or the trim or the cabinet virating on back of shell. Hope this helps
SOURCE: Sub zero fridge Mod# 642-F Ice maker
Make sure the arm is down, and make sure the tube coming in from the
back of the icemaker is not frozen. If it's frozen, use a hair dryer to
thaw out. If you see ice inside the mold of the icemaker but its' not
advancing, replace the icemaker. If you DON'T see ice, then you likely
have a bad electronic water valve if your unit is still getting a good
water supply.
Regarding the part, you could buy them from :-
http://www.repairclinic.com/Sub-Zero-Refrigerator-Ice-Maker-Or-Components-Parts
You should call up the repairclinic on 1-800-269-2609, 8 am to midnight ET, 7 days to make sure that you have the correct part ordered.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
361 THATS AN OLDIE
WATER VALVE IS LOCATED LOWER LEFT AT BOTTOM OF FRIDGE YOU WILL HAVE TO REMOVE 2 PHILLIPS SCREWS THAT HOLD LOWER KICK PANEL BE CAREFUL NOT TO UNHOOK THE DRAIN TRY OR THE DEFROST WATER MAY LEAK ONTO FLOOR
THERE IS A GOOD CHANCE THE WATER VALVE IS WORKING DUE TO THE AGE THE WATER INLET TUBE MAY HAVE FROZEN DUE TO INSULATION BREAK DOWN
CHECK WHITE TUBE GOING INTO ICE MAKER
THERE IS FILL TUBE INLET HEATER IF THIS IS THE CASE
THE PLASTIC TUBE THAT CONNECTS WATER VALVE COULD ALSO BE BRITTLE AND BROKEN
THIS YOU WILL KNOW WHEN YOU GET THAT LOWER KICK OFF AS WATER WILL SPRAY BEHIND UNIT
IF WATER VALE COIL IS GREEN AND BURNT OUT REPLACE ICE MAKER AS WELL AS THE GREEN VALVES ARE DESIGNED TO BURN OUT AFTER 45 SECONDS IN THE EVENT ICE MAKER JAMS (TO PREVENT FLOOD)
