Question about Sub-Zero 690 Side by Side Refrigerator
Door gasket Very hot and also metal strip very hot asa well
ACME Sub Zero Refrigerator Freezer
    Habit-Forming:
  • 41 Answers
Check if condenser fan motor is running and condenser unit - it might be full of dust and lint - clean it! It is dangerous for both compressors if that fan motor has stopped working! These parts located on top behind that alluminum grill, on right hand side. Sub Zero refrigeration condenser cleaning - Read instructions here:
http://www.subzerolosangeles.com/how-to-clean-a-condenser-on-a-sub-zero-refrigerator/
door gasket Very  hot and also metal strip very ho - f048cb07-64ac-4824-babe-8e01733e6ddc.jpg
Sub Zero refrigerator repair service and parts in Los Angeles
Posted on Jul 22, 2014
GB3RND
    New Friend:
  • 45 Answers
These are classic symptoms of 1. dirty condenser or 2. a malfunctioning condenser fan. Please check these 2 things by opening the louvered panel. The condenser is the part that looks like a small radiator. If you haven't cleaned it recently it is likely rather dirty. These should be cleaned every month or two to maintain proper operation. If your problem persists after this is clean, you will want to make sure the fan mounted right behind this is functioning.
Posted on Jul 24, 2014
How to change the freezer gasket on a Sub-Zero 650?
In my opinion this the easiest sub zero door gasket to install.The main reason for this is because of the way its packaged in the box from the factory.Not being twisted up makes it way easier then any of the others. And yes the first thing to do is remove the food and then pull the drawer out. Then loosen all the the quarter inch screws holding the metal strip that keeps the gasket in place but don't remove them just loosen. Once those are lose remove the old gasket. You should also remove the screws on the end of each metal strip. This helps when re-installing the new gasket. Now put freezer door face down with both rails sticking straight in the air and you can drop the gasket over the rails. The gasket has a small round bead that tucks in behind the metal strip. As you tuck this behind the strip work your way around the door snug in the screws be sure not to tighten them to much.Once in place take a hair dryer and warm any places that look wrinkled or need straightening. Finally tighten all screws including the eight corner screws now re-install freezer door and your finish.
Mar 25, 2014 | Sub-Zero 650 / O Bottom Freezer...
Where would I find the model number for my Amana side by side refrigerator.The problem I have is that the freezer section is keeping solids frozen,but not ice cream and concentrated juices.I noticed the...
Most of the time when the strip is hot it is due to the condenser coils being clogged. If you pull the kick plate off under the door, you should find some coils with dust, hair, and other various debris that has to be cleaned off the coils. These coils can become insullated with dust bunnies and not allow the freon to release enough of the heat as it flows through the coils. The coils actually run through the cabinet where the metal strip is getting hot. Break out a vacuum and clean off the coils and then give it a day and the unit should begin operating properly again. If you can't find the coils underneath remove the back access panel and they should be located to the right of your fan. Also make sure the fan itself is running. The fan is what moves the air flow under the fridge to cool the coils, if it is not running it can cause the same issue.
May 25, 2011 | Amana Refrigerators
Replacing door gaskets on model EF19MKXSN00
The gasket is held in place by metal strips on all 4 sides with a lot of screws. Loosen do not remove the screws and pull the gasket out from under it, Warm the new gasket in some hot water and tuck back under the retainers. Tighten the screws snug not overly tight. Use a heat gun or hair dryer to seat the new gasket and remove the wrinkles. Careful not to overheat and melt it.
Eric
Oct 21, 2009 | Whirlpool Refrigerators
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
I hve to replace a gasket on a refrig door i have the part but it doesnt have any adhesive do i need a glue or heat it in place id also like to know the best way to remove the current gasket which seems to...
Normal fitting for a door gasket is plastic pop buttons which go through the edge of the liner then through the gasket and into pre-drilled holes in the fridge door.
Some older uinit has stainless steel self tappers doing the same job.
You will probably find that if you place a normal dinner knife under the current gasket between it and the door you will be able to prise the thing off
Make sure that you are not too heavy handed about it in case you snap the buttons off
Jul 16, 2009 | Refrigerators
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 596.50692000 refrigerator. Every time I shut the refrigerator door, the freezer door pop open. What can I do? Do I need to replace the magnetic strip around the door? Who can give me instructions?...
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Let me know if this helps, Thanks, Sea Breeze
Mar 25, 2009 | Kenmore Refrigerators
How do i adjust doors so that they close on their own?????????????
Below is instructions on how to make sure doors open and close properly. Ignore the popping open part if this is not happening for you.
Mar 20, 2009 | GE Refrigerators
Kenmore Frig-bottom freezer/freezer door pops open
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Feb 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator Logo
14,482 people viewed this question
Top Sub-Zero Refrigerators Experts
john h
Marvin
Marvin
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
