Toshiba SDV393 DVD Player/VCR Logo
Posted on Sep 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want the code to make it multi-region themodel is sdv393
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470452
Points
19564
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
2answers
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
3helpful
4answers
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Multi-region code hack
Multi region code for samsung dvd 5500
um there is a reason why there is differ region dvd's...no player will play multi unless u buy it that way....best bet is to convert your wrong region dvd's to non region
3answers
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Phillips dvdr3510 multi region unlock code
Multi region? You should just be thankful it works.
The 3510 is the worst machine i've ever come across!
Yamaha DVD S1700 player multi-region unlock code
see if this works
  1. Power on
  2. Press PLAY
  3. Enter 2, 7, 4
  4. Enter 222 222 005 255
  5. Press PLAY
  6. Power off
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
