I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Very good suggestion by Jeffers99. I have had the same problem with my Electrolux ESL 459. Turned on the power, light fixed at 55 deg., and after 5 minutes or so the machine made the sound of a "finished cycle". Problem solved.
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
NCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category
