Question about Casio Pathfinder PAG40B-2V wristwatch
How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
Posted by jonmendicell on
Janelle Schoonover
  • 842 Answers
Thank you for contacting FixYa.
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Posted on Sep 20, 2010
    forrest
      New Friend:
    Lots of patience and clean workplace! batteries are .99 shipped on ebay for 20 batteries (a lifetime supply) springs are tough to make buttons bounce back CHECK ALL BUTTONS for spring reflex (will the buttons stay down or pop back? they need to pop back) before putting back on. AC is a hole with 4 little brass dots. stick wire in hole and other end to tops of batteries.
    Posted on May 24, 2012
    I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
    The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
    May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
    Where can I get a replacement band?
    Ebay is a great place for special watch bands. this one is $30:
    http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
    You can also go to the source, Casio, and purchase a new band:
    http://www.casio.com/support/buyparts/
    Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
    Need shell/bezel
    Either send to Casio or get new watch. I go with the latter
    Sep 22, 2012 | Casio Pathfinder PAG40B-2V wristwatch
    How di i change the batteries in my Casio Pathfinder 2782
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    The screen is swithing between compass - baro -
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
    Feb 27, 2010 | Casio PAG40B-2V Wrist Watch
    I have a PAG40 model and sensored functions are not reading. all it shows is "RECO" on top
    It may help if you check my tips and tricks. Find CASIO manuals/instructions there and see if it works.
    Jan 23, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Want to change out bands
    Here is the link:
    Even if you are not happy with that, do not forget that I did exactly what you asked for (found where to by).
    So, rate me accordingly to what I did , not the website.
    Thanks
    Mar 22, 2009 | Casio PAG40B-2V Wrist Watch
    Casio Pathfinder PAG40B-2V wristwatch Logo
    1,958 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Bruce Robin
    Are you a Casio Watch Expert? Answer questions, earn points and help others
