Question about Casio PRG-40T-7 Pathfinder
Change battery on a casio pathfinder 2271 - Casio PRG-40T-7 Pathfinder
Posted by ejs1264 on
Chris
    New Friend:
Anonymous
    New Friend:
It needs a reset or "all clear". look carefully on the "frame", it should have a stamped arrow marked "AC" with one or more contact points at the spot pointed to by the arrow. Touch a thin wire from the top (+) of a battery to one of these contacts, repeat until the watch resets.
Posted on Oct 25, 2009
1 Related Answer
Anonymous
  • 73 Answers
SOURCE: Repliciment wrist gand for Casio Pathfinder
you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
Posted on Jan 07, 2008
I am changing the batteries in a Casio model 2271 watch. A small silver spring fell out during disassembly. Can you tell me where it goes back?
just bring your casio watch to casio service center, i'm sure they have what you are lookin for.
Jul 14, 2011 | Watches
I replaced all four batteries and i still have nothing .inside the watch it says to jumper the A C point with a twizers. what is the AC point and where.this s a casio 2271 2years old had factory batteries...
Casio battery changes are quite tricky.If you look closely at the watch module there is a place for the battery and a v-small depression usually circular on the silver module .There will be the letters AC in small writing.You need to touch the depression AC and the battery at the same time with a conductive tweezers.This shorts the module and re sets the watch.Make sure any seals go back in to protect from water/dust.
Regards
Aug 13, 2010 | Casio PRG-40T-7 Pathfinder
How to restart my casio module no 2271 watch
mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
How do i change the batteries in my 2271
The safest option is to take it to a watch shop and ask them to change it for you.
While removing the back and replacing the battery,(assuming that is has a similar back to mine, which is the same make),is not too difficult, it can sometimes cause problems and since the charge for this is quite small, it is not worth taking any risk is getting it wrong. (Particularly difficult is making sure that the seal is properly made).
Considering the cost of you watch I would advise against doing it yourself.
Jan 25, 2010 | Casio PRG-40T-7 Pathfinder
6 year old Casio no. 2271 has ceased responding to buttons
Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
Jan 02, 2009 | Casio PRG-40T-7 Pathfinder
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Jan 05, 2008 | Casio Casual Sports Watch HDC6007BVCF
Casio PRG-40T-7 Pathfinder Logo
7,851 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Robert
Are you a Casio Watch Expert? Answer questions, earn points and help others
