Question about Casio PRG-40T-7 Pathfinder
How di i change the batteries in my Casio Pathfinder 2782
Posted by luckyluckylo on
Janelle Schoonover
  • 842 Answers
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Posted on Sep 21, 2010
    Casio sea pathfinder sp60d reset
    You need to open the watch and cortocircuit 2 points into the watch machine.
    TicTacArea.com is Officla Casio Dealer
    Casio Watches
    Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
    Casio pathfinder battery operated watch keeps blanking out display?
    Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
    For more information, you can download the manual of your watch here (direct download link):
    Timepieces Watches Manuals CASIO
    Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
    I just changed the battery on a Casio watch A158W and now the alarm and hourly chime doesn't work.
    The replacement battery may not have been installed properly. It can be a tricky operation. Also, the replacement battery could be ng.
    May 31, 2013 | Casio Pathfinder PAG40B-2V wristwatch
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to restart my casio module no 2271 watch
    mcdevito75 here, I'm figureing you"ve changed the battery, Pressing the MODE button should re-start your watch. If you didn"t change the battery and your watch just stopped, try pressing the MODE or any button to re-start the watch. If nothing, change the battery and repeat the above instructions.
    Jun 23, 2010 | Casio PRG-40T-7 Pathfinder
    Casio Pathfinder Digital Compass will not calibrate
    http://pathfinder.casio.com/support/manual/
    find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
    Jan 25, 2009 | Casio PRG-40T-7 Pathfinder
    Casio PRG-40T-7 Pathfinder Logo
    2,048 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Bruce Robin
    Are you a Casio Watch Expert? Answer questions, earn points and help others
