Tip & How-To about Cameras
How to import photos to computer
1.If you have mac Operating System You surely need your driver cd came with your camera.
2.Install your driver software to the computer.
3.You want a Usb Data cable for your particular camera .
4.Then connect your camera with the data cable .
5.And another end to the usb port.
6.Now your camera can detected by the computer.
7.Open your camera partition in the computer.
8.Now you can view the photos taken by the camera.
9.Using the copy and paste (cut&paste) or import photos option to import your photos to the computer.
10.This is the way to import the photos from the camera to computer.
Cameras Logo
plugged it in, not working!
Hello!
The situation is a bit confusing as I do not have any details, but let's try solve it together.
Variable webcam models require variable system values and editions.
Please read and follow these steps:
A. First uninstall your camera: Start>Control Panel>Uninstall a Program> find your webcam in the list, click on it and click Uninstall/Change>Confirm/Allow if prompted.Restart your computer.
B. Your webcam's requirements are following:
  • MacOS X 10.4.11 and 10.6.x for iChat and Skype
  • Windows XP(SP2) and Windows Vista for Windows Live Messenger, Skype and Yahoo! Messenger
  • Any desktop or notebook computers with a USB2.0 port available
  • I wish you told me what Operation System you use, as in that case it would be much easier to provide you a good solution.
    • To see which Operating Program you use click on Start, right click Computer and click Properties and you will enter System where all the information about your Operating System s listed. The first line in the first paragraph is the name of your Operating System.
    1. If running Mac:
    As you see in the requirements for installing your webcam you need MacOS X 10.4.11 or more (10.6.x for iChat and Skype), so if you are running less then you need to update.
    Tips on how to update your Mac you can find here:
    http://support.apple.com/kb/HT1338
    2. If running XP:
    Please, make sure your XP is up to date by checking Windows Update (Start>type Windows Update and click enter>click on Check for Updates in the left pane and wait until Windows Update download and install Available updates. You can also check on www.microsoft.com for latest XP updates.
    Note that for now, XP latest update is Service Pack 3: if your Operating System is up to date it should be listed when you open System as I provided above, but still run Windows update just to make sure.
    3. If running Vista:
    Please make sure your Vista is up to date and running Service Pack 2. The info you get in System as I provided above in bold.
    If you do not find Service Pack 2 in your System list (Service Pack 1 or none instead), then please run Windows Update (described in 2.). If you do not get Service Pack 2 automatically, then please visit www.microsoft.com click on Downloads, click on Vista and then double click on Service Pack 2.
    Download it and install, and then restart your computer.
    Check for updates using Windows Update, install any new updates available and restart your computer.
    Now about the USB2 requirement, you need to see your computer specifications as I do not know which computer you use (manufacturer, model).
    C. Install your camera:
    Insert the camera drive CD and if the installation does not start automatically, please do the following: double click on Computer on your desktop>double click on CD/DVD>double click on Driver>Allow/Continue if prompted. If the program prompts you to plug the camera, then you do so and continue installation.
    Restart your computer after the installation is done.
    D. Update camera driver:
    Click Start>right click Computer>click Manage>Device Manager.
    Find your camera in the list, right click on it and click Update. Plug the camera if prompted and continue.
    Restart your computer. Now the device should be working.
    Regards!
    2answers
    i dont know how to install my camera in computer
    1)FIRST INSERT DRIVER CD INTO CD ROM/DVD
    2)RUN THIS SOFTWARE BY INSTRUCTIONS
    3)CONNECT YOUR CAMERA BY USB/PORT
    4)START USING
    how can i use my web cam of oy lenovo g460. is there any software required?
    Hi mbisht19,
    Based on your concern, I suggest trying the following steps:
    1. Make sure that the updated driver has been installed on your computer.
    --> you can download it here:
    --> go to camera section and make sure you download the driver that matches your operating system.
    2. After downloading, install the driver then restart your computer.
    3. Log back in then try pressing the FN+ESC to activate the camera.
    4. Now try to use easy capture to check if the camera is working.
    --> easy capture is a preloaded application in your system.
    --> if you cant find easy capture, you can download it here:
    --> go to software section.
    --> again make sure that you download the application that matches your operating system.
    5. repeat step 2 and 3 then open the easy capture.
    Hope it helps,
    Thank you for using FixYa.
    I CAN'T COPY THE DATA FROM CAM TO PC
    can't get it networked on my mac that has windows parallel xp cant find it
    Hi
    I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
    Problem: Cannot get network on the Mac not specified
    OS : MAC computer Windows installed on it
    Printer Office jet 6500 Wireless.
    Solution :
    There are few thing which are required to know before we start trouble shooting
    IMPORTANT : Before you can install the product, your wireless network must already be set up. (To set up your network, follow the instructions that came with your particular access point.)
    IMPORTANT : Before you can install the product, you must have the following information about the network:
    • Network name : The network name is the SSID (Service Set Identifier).
    • Password : WEP key or WPA passphrase
    For a new product:CD installation is a quick and easy method and if you do not have a CD, you can download the software you need.
    CD installation : CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released as the software on the CD is current to the date of the product release.
    Downloading the HP Drivers :Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues. Downloading is also the recommended method if your computer operating system released after the HP product released. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market ..
    Wireless installation: If you have not previously installed the software, follow these instructions.
    Step one: Prepare for installation
    1 Make sure that you have the following requirements before you begin:
    • Network name: The network name is the SSID (Service Set Identifier).
    • WEP key or WPA security passphrase
    • A computer that is connected to the wireless network.
    • Internet access. HP recommends broadband Internet access such as cable or DSL.
    • Your wireless-capable HP product. Place it close to the computer during the installation procedure.
    • A USB cable (used only during installation).
    • Administrator privileges or password
    2. Make sure the product, access point, and computer are all on, and that the computer is connecting to the wireless network.
    3. Connect the USB Cable to the rear port of the HP product and to any USB port on the computer.
    4. Exit all applications running on your computer.Install the software
    To install the product software, follow the steps for the method that you want to use (CD or download).
    Method one: Install the software with the software CD
    1. Insert the Macintosh product CD into the CD drive of the computer.
    2. Double-click the HP software disc icon that displays under the Xp/Macintosh HD icon.
    3. Double-click the HP Installer icon. The HP Installer program opens.
    4. Follow the on-screen instructions to start the installation.
    5. When prompted to set up your device and software, select Continue .
    6. If a check mark does not appear, select Configure your device for a wireless network , and then select Continue.
    7. Follow the on-screen instructions to finish installing the software
    Option two: Change connection type
    1. Open HP Device Manager.
    2. From the Information and Settings drop-down menu, click Setup Assistant . 3. The HP Setup Assistant window opens.
    4. Follow the on-screen instructions to change your connection type to an existing wireless network.
    Top Cameras Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Are you a Camera Expert? Answer questions, earn points and help others
