Hello!
The situation is a bit confusing as I do not have any details, but let's try solve it together.
Variable webcam models require variable system values and editions.
Please read and follow these steps:
A. First uninstall your camera: Start>Control Panel>Uninstall a Program> find your webcam in the list, click on it and click Uninstall/Change>Confirm/Allow if prompted.Restart your computer.
B. Your webcam's requirements are following:
I wish you told me what Operation System you use, as in that case it would be much easier to provide you a good solution.
As you see in the requirements for installing your webcam you need MacOS X 10.4.11 or more (10.6.x for iChat and Skype), so if you are running less then you need to update.
Tips on how to update your Mac you can find here:
http://support.apple.com/kb/HT1338
2. If running XP:
Please, make sure your XP is up to date by checking Windows Update (Start>type Windows Update and click enter>click on Check for Updates in the left pane and wait until Windows Update download and install Available updates. You can also check on www.microsoft.com for latest XP updates.
Note that for now, XP latest update is Service Pack 3: if your Operating System is up to date it should be listed when you open System as I provided above, but still run Windows update just to make sure.
3. If running Vista:
Please make sure your Vista is up to date and running Service Pack 2. The info you get in System as I provided above in bold.
If you do not find Service Pack 2 in your System list (Service Pack 1 or none instead), then please run Windows Update (described in 2.). If you do not get Service Pack 2 automatically, then please visit www.microsoft.com click on Downloads, click on Vista and then double click on Service Pack 2.
Download it and install, and then restart your computer.
Check for updates using Windows Update, install any new updates available and restart your computer.
Now about the USB2 requirement, you need to see your computer specifications as I do not know which computer you use (manufacturer, model).
C. Install your camera:
Insert the camera drive CD and if the installation does not start automatically, please do the following: double click on Computer on your desktop>double click on CD/DVD>double click on Driver>Allow/Continue if prompted. If the program prompts you to plug the camera, then you do so and continue installation.
Restart your computer after the installation is done.
D. Update camera driver:
Click Start>right click Computer>click Manage>Device Manager.
Find your camera in the list, right click on it and click Update. Plug the camera if prompted and continue.
Restart your computer. Now the device should be working.
Regards!
