20 Most Recent Macally IceCam2 Web Cam Questions & Answers
Free software download
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark ? right click to reinstall drivers or update driver xp. Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer If you still have no webcam installed Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next" to continue. Wait while Windows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system. Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder. Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next" button to install the driver, then reboot the computer to add webcam functionality. Webcams come in a wide array of styles and designs, from the very simple to the elite, but they all have one thing in common: They can be adjusted to match your mood at the moment and creative desires. Open your web cam in a chat program, such as Skype. Look for a link called "Preferences," where you will find webcam options you can adjust. Choose the "Camera Settings" option and another window will open, labeled "Properties." There are more options here that can be adjusted. Change a setting, such as brightness, by clicking on the slider mechanism with your pointer and dragging it. These mechanisms are usually pretty sensitive, so be cautious when moving the settings. Make sure that the image on your webcam is clear and in focus.
5/26/2013 6:36:17 AM • Macally IceCam2... • Answered on May 26, 2013
Lighting
5/26/2013 6:34:48 AM • Macally IceCam2... • Answered on May 26, 2013
A friend gave me an icecam2 from Macally but without the drivers, Is there anybody that has the drivers for xp? Their website does not have them?
1st You download Webcam Driver.A friend gave me an icecam2 from Macally but without the drivers, Is there anybody that has the drivers for xp? Their website does not have them?After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
1/21/2013 10:08:16 AM • Macally IceCam2... • Answered on Jan 21, 2013
I installed IceCam. In the
1st You download Webcam Driver.I installed IceCam. In theAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
1/21/2013 10:07:20 AM • Macally IceCam2... • Answered on Jan 21, 2013
How to install Macally IceCam2
1st You download Webcam Driver.How to install Macally IceCam2After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
1/21/2013 10:06:28 AM • Macally IceCam2... • Answered on Jan 21, 2013
How do you install icecam2 on g4 mac?
1st You download Webcam Driver.How do you install icecam2 on g4 mac?After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
1/21/2013 10:03:46 AM • Macally IceCam2... • Answered on Jan 21, 2013
Drivers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
1/2/2013 4:52:26 PM • Macally IceCam2... • Answered on Jan 02, 2013
Plugged it in, not working!
Hello!
The situation is a bit confusing as I do not have any details, but let's try solve it together.
Variable webcam models require variable system values and editions.
Please read and follow these steps:
A. First uninstall your camera: Start>Control Panel>Uninstall a Program> find your webcam in the list, click on it and click Uninstall/Change>Confirm/Allow if prompted.Restart your computer.
B. Your webcam's requirements are following:
  • MacOS X 10.4.11 and 10.6.x for iChat and Skype
  • Windows XP(SP2) and Windows Vista for Windows Live Messenger, Skype and Yahoo! Messenger
  • Any desktop or notebook computers with a USB2.0 port available
  • I wish you told me what Operation System you use, as in that case it would be much easier to provide you a good solution.
    • To see which Operating Program you use click on Start, right click Computer and click Properties and you will enter System where all the information about your Operating System s listed. The first line in the first paragraph is the name of your Operating System.
    1. If running Mac:
    As you see in the requirements for installing your webcam you need MacOS X 10.4.11 or more (10.6.x for iChat and Skype), so if you are running less then you need to update.
    Tips on how to update your Mac you can find here:
    http://support.apple.com/kb/HT1338
    2. If running XP:
    Please, make sure your XP is up to date by checking Windows Update (Start>type Windows Update and click enter>click on Check for Updates in the left pane and wait until Windows Update download and install Available updates. You can also check on www.microsoft.com for latest XP updates.
    Note that for now, XP latest update is Service Pack 3: if your Operating System is up to date it should be listed when you open System as I provided above, but still run Windows update just to make sure.
    3. If running Vista:
    Please make sure your Vista is up to date and running Service Pack 2. The info you get in System as I provided above in bold.
    If you do not find Service Pack 2 in your System list (Service Pack 1 or none instead), then please run Windows Update (described in 2.). If you do not get Service Pack 2 automatically, then please visit www.microsoft.com click on Downloads, click on Vista and then double click on Service Pack 2.
    Download it and install, and then restart your computer.
    Check for updates using Windows Update, install any new updates available and restart your computer.
    Now about the USB2 requirement, you need to see your computer specifications as I do not know which computer you use (manufacturer, model).
    C. Install your camera:
    Insert the camera drive CD and if the installation does not start automatically, please do the following: double click on Computer on your desktop>double click on CD/DVD>double click on Driver>Allow/Continue if prompted. If the program prompts you to plug the camera, then you do so and continue installation.
    Restart your computer after the installation is done.
    D. Update camera driver:
    Click Start>right click Computer>click Manage>Device Manager.
    Find your camera in the list, right click on it and click Update. Plug the camera if prompted and continue.
    Restart your computer. Now the device should be working.
    Regards!
    6/25/2011 10:02:09 PM • Macally IceCam2... • Answered on Jun 25, 2011
    witch version of OSX are you using you may need to upgrade
    Requirements • MacOS X 10.4.11 and 10.5.x for iChat
    6/4/2011 5:25:59 PM • Macally IceCam2... • Answered on Jun 04, 2011
    My IceCam2 on my Mac PowerPC 0S X 10.4.11
    Download and install the IceCam Drivers ...here ...
    Also try a different usb port.
    2/11/2011 1:48:50 AM • Macally IceCam2... • Answered on Feb 11, 2011
    My Macally IceCam2 won't turn on. The green light
    Once you have properly install the software drivers for
    camera, DO NOT UNPLUG it from the USB port unless
    you have powered down your laptop computer or
    Desktop Computer as it will cause the Camera drivers
    to become corrupt.
    Like wise plug the camera into the
    USB port before powering up your laptop or the
    desktop computer so it will recognize the camera and
    drivers that are installed.
    Do this to get the camera working again.
    Follow the instructions below and it will work.
    Disconnect the Camera from the USB port and reinstall the CD or
    Downloaded software program.
    When the program asks you to connect the camera to the USB port,
    do so and it should work.
    Then to use it on the Web, do this.
    Web Camera's have to be setup on the program they are to be used
    with. Just installing the camera on your computer does not set it up
    to broadcast on
    messengers or Skype.
    Each program has Options that have to be setup in order for the Audio
    and Video to function properly.
    A. Skype Setup:
    After downloading and installing Skype
    http://www.skype.com/intl/en-gb/download/skype/windows/beta/
    downloading/
    set it up as follows:
    Go to Tools, then Options, and click on Audio Settings and set the
    Microphone and Speakers to the computer Audio Card.
    Then click on the Video Settings.
    The camera, if Installed Properly, it will come up and show a video
    picture.
    Then, on the bottom of the page click save.
    The camera and audio should function properly. Your friends and
    Family will now be able to see and hear you.
    B. Yahoo Setup:
    After downloading and installing Yahoo Messenger
    http://www.soft32.com/download_30.HTML
    Go to Messenger at the top left and click on it.
    Next go down to Preferences and click on it.
    Next Calling and Devices on the right and set the Microphone and
    Next go to the Test Audio section and (in blue writing) click on "Open
    the call setup assistant" and follow the instructions on the left window.
    C. Windows Live Messenger:
    http://download.live.com/Messenger
    After you start Windows Live Messenger, expand the view by clicking
    on the square on top left next to the red X.
    Then on the Windows Live messenger window on the right side, click
    on " "Show Menus." And then click on "Show the Menu Bar".
    Next go to the Menu Bar on right side, click on " "Action."
    Go to "TOOLS" and click "Audio and Video Setting" and follow the
    instructions.
    NOTE: Your audio and video should work. Enjoy.
    When done both the Audio and Video will function properly so you can
    chat and see family or friends you are connected to.
    D. AIM (AOL) Messenger:
    http://dashboard.aim.com/aim
    On the VIM sign-in window click on Edit.
    Then click on Settings Enhanced IM.
    Next click on Enhanced IM.
    Then click on Audio Video.
    The Audio and Video portion has drop downs so you can select the
    proper audio card and video camera installed in you computer.
    The Audi Video drop downs are
    Microphone
    Speaker
    Camera
    The audio and camera should function now.
    Additional information to use with VIM settings.
    Adjust Your Audio and Video Settings:
    In order to adjust your audio and video settings, please follow the steps
    given below:
    1. Click the Audio and Video Settings button directly below the My
    Buddy or My Camera window. If you are currently
    Participating in an AOL Live Video IM session, a message will display:
    You must disconnect the current AOL Live Video IM Conversation
    before running setup. Would you like to disconnect now? Click the
    Yes button.
    2. The Audio and Video Tuning Wizard will appear to help you verify
    that your camera, speakers and microphone are working
    Properly. Follow the on-screen prompts.
    Notes:
    The first time you use AOL Live Video IM, a message will display:
    Would you like to first check your audio and video settings? Click the
    Yes button.
    The Audio and Video Tuning Wizard will appear to help you verify that
    your camera, speakers and microphone are working properly.
    images in AOL Live Video IM may appear reversed, or as a mirror
    image (text may appear backwards) when you look at your own
    camera feed or at the
    Picture-in-picture (PIP) display.
    After making the settings your ready for a chat and video talk with
    your Family and Friends.
    Hope this helps. Bud
    2/4/2011 10:17:55 PM • Macally IceCam2... • Answered on Feb 04, 2011
    Camera does not work - green light does not come
    Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
    When the program asks you to connect the camera to the USB port, do so and it should work.
    Web Camera's have to be setup on the program they are to be used with. Just installing the
    camera on your computer does not set it up to broadcast on messengers or Skype.
    Each program has Options that have to be setup in order for the Audio and Video to function properly.
    A. Skype Setup:
    http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
    Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
    The camera, if Installed Properly, it will come up and show a video picture.
    The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
    B. Yahoo Setup:
    Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
    Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
    After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
    Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
    Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
    When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
    The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
    Microphone
    Speaker
    Camera
    In order to adjust your audio and video settings, please follow the steps given below:
    1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
    Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
    Conversation before running setup. Would you like to disconnect now? Click the Yes button.
    2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
    Notes:
    The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
    The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
    images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
    After making the settings your ready for a chat and video talk with your Family and Friends.
    12/26/2010 7:38:30 PM • Macally IceCam2... • Answered on Dec 26, 2010
    No sound from the audio
    To work around this behavior, use digital output or analog speakers.
    To switch to digital CD playback:
    1. Start Windows Media Player.
    2. On the Tools menu, click Options.
    3. Click the Devices tab, and then click Properties for the CD-ROM or DVD-ROM drive that you are using for playback.
    4. In the Playback section, click Digital.
    5. Click OK, and then restart the playback.
    10/25/2010 7:30:59 AM • Macally IceCam2... • Answered on Oct 25, 2010
    Can I leave my Macally rechargeable bluetooth keyboard n all the time? Even when computer is off. What is expected battery life?
    the manual should cover that. but varies, on actual use. the keyboard goes to sleep. the longer is sleeps the longer the battery last. why not just let it do its thing until it dies or makes chararcters like this ou[aopiup0[ep[ ibp[em iepoifpeo[p[eifkp no model keyboard told so can not RTM to you.
    1/6/2022 3:01:38 PM • Macally... • Answered on Jan 06, 2022
    Macally IceCam2 Web Cam Logo
    Popular Tags
    31 questions posted
    Top Macally Computers & Internet Experts
    Paul Bade
    Mike
    Muzahura Frank
    Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Macally Computers & Internet
    Most Popular Question
    plugged in not working
    • Computers & Internet
