No card there. its cables and connector only
i cant see it do its dance so no answers possible.
ask the living?
obviously its broken and is inside.
some dv9000 have ccfl lamps that all die...
that greed deal sound serious.
get the service book , read how to remove keyboard
and flex the LCD cable there. it might just be loose.
https://h30434.www3.hp.com/
the pc is retired status now. no support page
but parts yes.
the parts page shows inverter and CCFL.
if the tubes fail they do go dim /flicker and turn yellow.
that yell can make other colors go green.
but I cant see it so IDK
SOURCE: hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
it is a design/manufacturing flaw in the gpu
nvidia is being sued over this
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
SOURCE: HP Pavilion dv6700 overheats & shuts down
I rebiold these things constantly and they are not that hard to keep clean. The first thing i do is remove the battery, remove all power and push the power button for 15 seconds to bleed off any stored power on the motherboard. I used compressed gas from a can that has been purified and sold ay office supply stores. Using short bursts, spray into one side of the laptop at a time starting with the ventilation grill and ducts as well as the cd tray. If you look at the cd door, there is a small black hole on the door, push a paperclip in that hole and will release the door so you can blow some air through the device to clean the dust out of it. Once you have blown all the dust, hair and debris out of it, start it up.
Now you may have to update the BIOS if you have not done so recently. HP updated most of the BIOS files for these models to make the fans run stronger and longer to help with cooling. The bottom line here is that this particular model is a lemon and the only true way to keep the processor from melting into glass is to attach a laptop cooler to that is powered off the usb port.
If you want to update the BIOS, go to the link below and put your full model number in the search box, then choose driver/software downloads. Look for the small drop down menu that asks what operating system you are using. Now choose BIOS from the list below and download the latest (newest) one. Once the download is complete, shut down all running programs and double click the downloaded program. This will start the BIOS installer. Make sure that both the battery is installed and you are on AC power when you flash the BIOS!!! Now, just follow the prompts i the program and flash the BIOS. Reboot when it is finished.
