There isn't a black hole in trucks that make things disappear. If it fell into the defroster ducts it's going to take some work to get it out, but I'm sure it's in there somewhere. May have to remove the dashboard and ducts to locate it. It won't be a fun job, but if the ring means that much to you, you don't have much choice.
The main reason why your TV won't turn on is because of its power supply board. This power supply board are composed of capacitors that are the responsible for the proper supply of current to your TV. If one or many of these capacitors are already burned out or "dead" your TV won't turn on at all. Here's what you've got to do:
1. Open your TV or let somebody do it, much better a technician. 2. Check the Power Supply Board. 3. Check the capacitors. Remove the "dead" ones and replaced it with "new" ones. You can buy capacitors to the nearest hardware in your town, or to your service provider.
I would suggest you to do it with a presence of a TV technician, so that you will be guided properly. Thanks for your question. I hope it helps....
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
The most probable solution is a new motor, but you may get lucky. I would first make sure that there isn.t something that fell down the filter hole and is caught in the blower blade. Possibly the rollers are jammed and won't let the drum go, but usually when it groans and won't go it is the motor
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
