20 Most Recent Philips Magnavox MS2530C 25" TV Questions & Answers
Black screen covering most of tv screen at a few channels
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
5/27/2012 11:59:38 PM • Philips Magnavox... • Answered on May 27, 2012
My TV fell from a
Try to see if any wires got loose? Or any pcboard got damaged? Or crt broke.
8/16/2010 10:50:27 PM • Philips Magnavox... • Answered on Aug 16, 2010
TV goes black, no sound or picture. Changing
There are several possibilite here, including the power supply, video amplifer circuit, and high voltage.
However, there is a componet on the main board that is the most likley fault. R3455 should be inspected and repaired or replaced as necessary.
Thank you
5/2/2010 3:10:40 PM • Philips Magnavox... • Answered on May 02, 2010
2answers
I purchased a Phillips/Magnavox TV, Model
on Philips any universal remote will work ...even a pilot simple one ...or a pocket size universal with no codes...this is a site where you will find the codes for Philips...and also I will link a eBay link with a universal mini one..
But if you got one like you said it will work great ...from a MS2530C..and even will have almost the same functions..
this is for the codes..
http://www.universal-remote.net/philipsmagnavox.html
this is a universal Philips ..that will work too...
http://cgi.ebay.com/Philips-Universal-Remote-SRU3003WM-17_W0QQitemZ250598287467QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a58d2686b
3/24/2010 12:13:26 PM • Philips Magnavox... • Answered on Mar 24, 2010
2answers
I have a tv that has smartlock on it. How can i
Leave unplugged for a few hours, press and hold power button for 5 seconds, wait half hour more, plug back in and it should reset, otherwise there may be a reset option in the main menu
12/22/2009 6:48:41 PM • Philips Magnavox... • Answered on Dec 22, 2009
Parental lock
Parental lock
11/25/2009 5:21:18 AM • Philips Magnavox... • Answered on Nov 25, 2009
Need a transformer for inverter board for ACER 19''lcd monitor.
About the best thing you can do is find a junk ACER monitor and take that one out. Buying parts separately for any lcd monitor/tv will cost you more then a new one (more times then none).
Where can you find one, Ebay, Craigslist, etc.. But make sure to look for a broken one, they will be cheap and worth while.
6/26/2009 12:55:25 AM • Philips Magnavox... • Answered on Jun 26, 2009
White line at top of tv screen & picture flips back over itself
caps in vert.output.
6/25/2009 11:59:02 PM • Philips Magnavox... • Answered on Jun 25, 2009
2answers
TV scrambles
Sounds like from what your describing, a horizontal sync problem and there are a few capacitors in this model that does cause that. If your not a tech this is something you should mess with as the way to trouble shoot this problem would be by using a scjhemetic, a isolation transformer and an ocilliscope. its a possiblity that you could also have a tune rproblem thats giving the sync separator circuit a weak sync pulse from the video its putting out. Good Luck
6/25/2009 11:57:38 PM • Philips Magnavox... • Answered on Jun 25, 2009
TV WONT GO TO VIDEO CHANNEL
most inexpensive universal remotes will not operate input select functions. save yourself some hedaches, go to shopjimmy.com, enter yuor model# and buy an original remote, my dear! you'll thank me later! :) mch
3/9/2009 1:46:35 AM • Philips Magnavox... • Answered on Mar 09, 2009
Magnavox 27MS4504 clicks, then dies
as always ck for bad connections. slap side lift sid drop  otherwise not worth repair.
11/30/2008 8:48:21 PM • Philips Magnavox... • Answered on Nov 30, 2008
2answers
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
9/11/2008 4:08:29 PM • Philips Magnavox... • Answered on Sep 11, 2008
TV colors distorted
maybe UFO around.. just kidding the mask in your picture tube may be damaged if that set is drop by any chance if not deagausing coil circuit ..
4/1/2008 6:39:14 PM • Philips Magnavox... • Answered on Apr 01, 2008
Antenna
if you want o spend money on this is up to you that tunner may cost $80.00 plus and next year we wont need analog tunner so if you have video imputs use a vcr as a tuner or get converter box
4/1/2008 6:34:27 PM • Philips Magnavox... • Answered on Apr 01, 2008
Pictgure
looks like HVT I' had same problem job for experienced tech
4/1/2008 6:31:05 PM • Philips Magnavox... • Answered on Apr 01, 2008
Horizontal lines
may be vertical deflection circuit bad capacitors and is a job for experienced tech
4/1/2008 6:28:45 PM • Philips Magnavox... • Answered on Apr 01, 2008
Philips Magnavox MS2530C 25" TV Logo
20 questions posted
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv goes black no sound or picture
  • Televison & Video
