SOURCE: FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
SOURCE: using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
SOURCE: Sanyo VPC-T700 Wire
1. write a letter to the company to send you a new one.do payment via credit or debit card or talk some way eith them about the payment technique.
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
