Question about Protron Ac / Dc Power Supply For Protron Pltv-32 Pltv32 Lcd Tv
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
Posted by tsrcamp on
kongs12
    New Friend:
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Posted on Aug 23, 2011
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Need a dc adapter 12V, 3A/24V, 6A
  • http://www.lcdpayless.com/productpage.php?productId=3509
Aug 25, 2010 | Protron PLTV-32 Television
NEED DC ADAPTER
it is available at eBay
Apr 28, 2010 | Protron PLTV-32 Television
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
My ac adaptor for protron 32" lcd tv died. where can i find a replacement
you buy a new one or from computer power supply out 12 Volt Dc 4.3 amp make a output
then solve problem
Aug 28, 2009 | Protron PLTV-32 Television
July 1, 2009- I need to replace my burn-out ac
Try website. - http://www.lcdpayless.com I placed my order on Thursday and went out of town for the 4th and I checked my mail today (Monday) and it was there. I plugged it in, the power came on and the tv works perfectly....plus the new cord doesn't have an annoying fan.
The cord is pricey at $117, but it beats buying a new tv. The company accepts returns minus a 20% restocking fee and shipping, so I figured worse case scenario I would only be out of $40+bucks if it didn't work and I had to send it back. Hope this helps!!!
Jul 02, 2009 | Protron PLTV-32 Television
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
Protron Ac / Dc Power Supply For Protron Pltv-32 Pltv32 Lcd Tv Logo
228 people viewed this question
Top Protron Home Security Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Protron Home Security Expert? Answer questions, earn points and help others
