There is a green, hazy, upside down arch of color across the top of the tv screen and the directory wording is all blurry?
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Testimonial: "thank you for your quick response! I am a true blonde when it comes to technical stuff but now I know enough to be dangerous and I know what to say to the repairman when asking for help!"
As for the other TV you ask about, I cannot say what the problem is for sure. If this model is one of the last of the projection sets, you can be sure there are some bad solder grounds. I do not really know this model, have not repaired one. If this TV is a DLP, it may be that the color wheel has lost its rpm, as it should spin at about 14000 times a minute. Sorry I cannot really give you a concrete answer on this HDTV. Thanks for asking, and continue to visit this website!
Green tint with yellow words, shadowed by blue.
Would your advice be the same if this green tinge and blurry vision appeared on a Mitsubishi HDTV 1080, model #WS-55511? I am going to assume that it would be, but I want to make sure! Thank you.
