Quantaray 28-200MM F3.8-5.6 Lens for Canon AF Logo
Anonymous Posted on Jun 07, 2010
Canon C3380i E000025-0001 paper will not feed
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Jun 07, 2010
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1557331
Points
18452
You would probably need to remove the covers on this model to get a good look at the feed path something might be blocking there.
It could also be that the pickup roller is not gripping the paper, but you would have noticed the gradual increase in pickup problems.
If this is the case, may try and clean the pickup roller with a cotton wipe, cardboard moistened with citrus cleaner or eucalyptus oil.
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
We are printing 2 sided agendas which contain 44 pages each. The print from the first side is showing through on the second side. How can we fix this problem?
ia the paper you are using heavy or velum textured some papers with a textured surfaces are not compatible with copiers..the fuser section cannot heat the toner in the texture enough for it to adhere to page. check the same print job with normal paper and compare results..
Service Manual
I have it
pleas contact me at my E-mail
[email protected]
Only wants to print/copy on Legal paper
check that someone hasnt moved the paper size dial blue 1 in paper trays then do get device status in driver for printing my moneys on the dial been moved
Forward a received fax
its not easy to explain like this much better to download the user manual from canon web site its free to download in the uk anyway your looking for forward setting
2answers
My cannon imagerunner C3380i keeps jamming.
Make sure that the paper in the tray are set to the correct paper size. Also, the paper trays can be removed from the copier, remove them & look for any paper jammed or present blocking the paper path... Good Luck
Our networked canon printer misses out random letters sometimes
first try changing your fount, if this does not work reload drivers
Top Quantaray Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
