Send me mail on
[email protected], and I will send you service manual. Drum is service work routine, and it is not predicted to change by user.
If the developer in the drum unit is not made even, blank areas at the image
end or the error 'E020', 'E025' may occur.
Here is summary:
1) Open the front cover [1].
2) Press the claw down [1], and detach the handle cover
3) Press the release lever [1] to open the lower right cover [2] of the host machine.
4) Remove tapes and the protection sheet [3] attached to the duplexing unit.
5) Remove the 2 screws
) Turn the handle [1] by 180 degrees, and hold the handle [1] and the grip
[2] to slide the process unit [3] until it stops.
Press the push-button [1], and hold the grip [2] to open the ITB unit [3]
upward.
Secure the ITB unit [1] in place with the tip-resistant arm [2] (Secure in
the lower slot of the 2)
) Taking account of the following items, unwrap the packaging of all drum
unit according to the step 9-1) to 9-3).
9-2) Peel off the tape [1] and [2] to remove the antifriction sheet [
