SOURCE: Sony DSC-W120 Digital camera Problem: The
When i switch on the power button to take photo "E:91:01" code and flash symbol blinks on screen and flash
does not work also.
plz let me knw solution for this waiting for reply.
M talking about my sony cybershot digital camera model no DSC-W120
SOURCE: Memory card error when I turn on camera
oops.. looks like many card errors, as just now i gave reply to 2
Test the memory cards using external card readers connected to computer/laptop and see if it works.
If it doesn't, then it can be formatted from computer and tested on Pentax again.
If still it doesn't work on Pentax then it can also be a small issue
of contacts inside attracted dust. You can try using blower to clean
dust if any in the place you insert the memory card and try again.
If it doesn't work then it it needs visit to some experienced person/technician/mechanic.
SOURCE: sandisk sdhc 4gb memory card wont work with my
You need to format the card in the camera to optimize it.
SOURCE: I have bent pins in
At this point, you have two choices. You can send it in for service and you could try to straighten them yourself. If the bend is not severe, you could try coaxing them back into position with some kind of probe such as a dental pick or something similar. If you mess up, you still have the option of sending it for service. However, explain your problem in an e-mail to the service dept. and get an estimate first...you may decide it's not worth it.
most of the Still cameras do not require driver or software
to transfer images now a days.
Once you connect the Camera to the computer, you will get
the Camera as a removable drive under My Computer. You can open the removable
drive to see the pictures stored in the Camera/Memory Card.
If the Operating System installed in your Computer still
needs a driver, you may use the Memory Card slot on the Computer to transfer
the pictures. Please follow the steps to transfer pictures using Memory Card
Reader in the Computer:
Remove the Memory Card from the Camera.
Insert it in the Memory Card slot in the Computer.
Open the pop up window or find out the removable drive under
My Computer.
Copy the required files to a folder in the Computer.
Note : Most of the Notebooks comes with its own Memory Card
Slot. If it does not, you may get one from the market without much spending.
Thanks for understanding.
Please let me know if you need further assistance.
