20 Most Recent Kodak EasyShare ZD710 Digital Camera Questions & Answers
0answers
Error l03
Be the first to answer 12/14/2013 7:17:44 PM • Kodak EasyShare... • Posted on Dec 14, 2013Be the first to answer
My camera just stopped working
Completely dead? Have you checked the batteries? Did you try some fresh batteries? Did you check the contacts from the batteries and in the camera. They should be clean and shiny. eventually clean with a dry cloth, not with a sharp tool.Were you making lots of pictures in a short time? It could be the camera was over heating and (temporary) shut down. Leave it for a little while and try to use it again.I hope by the time you read this,the problem was solved.
11/12/2013 12:50:12 PM • Kodak EasyShare... • Answered on Nov 12, 2013
0answers
0answers
Hard reset
Be the first to answer 10/9/2013 3:46:21 AM • Kodak EasyShare... • Posted on Oct 09, 2013Be the first to answer
Card write protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
6/23/2013 1:28:00 PM • Kodak EasyShare... • Answered on Jun 23, 2013
New batteries in my kodak easyshare zd710 digital camera and it still says low battery and shuts off
This camera needs to go to shop, no user fixes for this so don't waste your time.
1/25/2013 12:20:23 AM • Kodak EasyShare... • Answered on Jan 25, 2013
When i take pictures, they come out overexposed and with lines
The camera has a censor problem, needs repair.
1/24/2013 7:49:54 PM • Kodak EasyShare... • Answered on Jan 24, 2013
How to take automatic pictures
If you mean in automatic mode, turn the mode dial on the back of the camera to the camera icon. If you mean using the self-timer so you can get in the picture, follow the instructions on this page of the use guide.
10/23/2012 6:38:19 PM • Kodak EasyShare... • Answered on Oct 23, 2012
ZD710 KODAK CAMERA
Look for the "Date & Time" command in the Setup menu (camera-and-wrench icon).
5/31/2012 8:44:30 PM • Kodak EasyShare... • Answered on May 31, 2012
Flash won't work
maybe some resistor in FLASH CIRCUIT section inside of your camera are opened because sometimes, this is what i find when im experiencing that kind of truoble,so i advice you to try first on the settings menu before consulting to a trained technician,.
2/23/2012 11:02:17 AM • Kodak EasyShare... • Answered on Feb 23, 2012
2answers
Drop my kodak easyshare zd710 and now it will no
Welcome to FixyaLooks like the mechanism already failing. Try to troubleshoot it first by taking the battery out. Press and hold the power button for 15 secs then put everything back. If same problem will occur then the problem is already the mechanismThanks If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
10/31/2011 2:46:43 PM • Kodak EasyShare... • Answered on Oct 31, 2011
I have a easyshare and it won't read a memory
Are you test with other SD card? CHeck pins alignement in the card slots.
9/23/2011 1:23:36 PM • Kodak EasyShare... • Answered on Sep 23, 2011
Can i use my kodak ZD710 digital camera as a web
I don't know why I bother to keep answering this particular question, because the few who bother to rate my answer rate it as if they hold me personally responsible for the camera's design, but here goes anyway.
No. The ZD710 was designed as a camera, storing high resolution images (and videos) to a memory card. It was not designed as a web cam, to stream low resolution videos live to another device.
7/7/2011 2:19:36 AM • Kodak EasyShare... • Answered on Jul 07, 2011
My Kodak ZD710 Will only
Welcome to FixYa.
Kodak lithium digital camera battery CRV3 (non-rechargable) approximately can take pictures up to 500 pictures. However, actual life may vary based on the usage.
How to extend your battery life?
1. Use power saving features (using a power saving modes). Limit activites such as reviewing pictures/videos on the LCD.
2. Dirt on the battery contacts can affect battery life. Wipe the contacts with clean,dry cloth before loading the battery in the camera.
3. Battery performance is reduced at temperatures below 41 F(5 degree celcius). When using your camera in cold weather, keep spare batteries warm. Do not discard cold batteries; when they return to room temperature, they may be usable.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
4/14/2011 7:22:26 PM • Kodak EasyShare... • Answered on Apr 14, 2011
Kodak Easyshare ZD710 does not take pics and shuts
A 1GB card is too large to be supported by the device.
3/4/2011 10:36:01 PM • Kodak EasyShare... • Answered on Mar 04, 2011
I just recently bought a kodak zd710. When i
Battery usually come with very little charge when new.You must first charge the battery before use the camera.
2/18/2011 1:56:52 AM • Kodak EasyShare... • Answered on Feb 18, 2011
Kodak EasyShare ZD710 Digital Camera Logo
38 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
drop kodak easyshare zd710 now will no
  • Cameras
