20 Most Recent
Canon Digital Rebel XTi Digital Camera Questions & Answers
Pics will not download to my computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
How do I download a
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe Reader Hope this helps. Thanks for using
FixYa.
Screen reads ERR CF, I think I can see a broken
This was a $1500 camera with the kit lens. It's certainly worth fixing if you still love it. If you secretly want a brand new camera, then "I would throw out this piece of junk";) Or, get the new camera and get this one fixed for a back-up.
My canon rebel xsi was working a month ago. Today
The reader in the camera has gone bad. You can get it repaired by anyone who fixes camera's or by sending it to Canon which will cost you more then finding someone in your home town that repairs cameras. Just FYI the repair is somewhat costly roughy 150 dollars or so
Card reader pins came out
Basically no. You need the pins to connect to the memory card to transfer and store photos from the camera to the card. There is no simple way to bypass it unless the camera can also use another type of memory card, in which case you use that second slot.
I am having trouble with computer not being able
Have a look at the pins at the back of the memory card reader. You may need a torch to see to the back. My kids stuck something in my computer card slot and bent the pins so my cards would not read.
Canon xti work turn on properly
Unfortunately, per the problem description, it seems your camera has an internal malfunction in either the main board or the DC/Dc converter printer cicuit boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the option of pay for its repair.
Best regards,
CANON REBEL XS
It can happen if you are in the Auto-No Flash mode. Or if the flash release button is stuck.
Contact customer service, and have a pro take a look at your camera.
Trying to download pics from computer and get error 31, but then camera automatically disconnects itself
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
