I have a J7009 Samsung phonbe and the time displayed on the main screen is 1 hour out. It still displays winter time (UK) How can I change the time displayed on the screen to UK Summer Time. I cannot find any way to do this. Any help greatly appreciated.
Hello,kindly follow the steps below,
MENU>SETTINGS>TIME AND DATE>THEN YOU CLICK ON TIME>THEN YOU ACCESS THE TIME ZONE>AFTER THIS YOU CLICK ON THE GMT.and definately your mobile phone time will then work perfectly again.
hanks for using fixya,
you are highly appreciated.
Testimonial: "Thgank you. Great help."
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
