20 Most Recent Samsung SV-DVD3E DVD Player/VCR Questions & Answers
I Have the same DVD /VCR but the cove will need to be taken off that there is a fuse in it ,on right side in the back on the circuit board . be sure it's unplugged .
Samsung SV-DVD3E... • Answered on Sep 11, 2013
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
Samsung SV-DVD3E... • Answered on Apr 20, 2013
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Samsung SV-DVD3E... • Answered on Oct 10, 2011
all diagrams can be found here on this full service manual
http://www.givemefile.net/smanuals/dsrvrc_players/samsung/sv-dvd3e.html
Please vote for me if you found this info useful
Samsung SV-DVD3E... • Answered on Mar 16, 2011
have a dvd/vcr combo,double image on tv when dvd is played, vhs works fine.
Samsung SV-DVD3E... • Answered on Mar 20, 2010
The built in light and the LED could be causing the TV screen to not having anything show up on the TV's screen. It would be more convenient to purchase a new TV instead of trying to repair the current one that you have.
Samsung... • Answered 2 hours ago
perhaps you have it set on the wrong input . many things a service tech has to see to FIX
Samsung... • Answered on May 06, 2021
The EU does not have parts availability like some other countries. With that in mind your unit can have a failure in the led strips that are behind the screen and the screen wont light properly, if this happens when the unit is on then you see half the picture, if the unit is shut off then when it is powered on, it senses the change in the current flowing in the back light strips and wont turn on at all. The process is to find the strips and replace them or if you are inclined and trained, troubleshoot the strips to find the individual LED that failed and replace only those.
Samsung... • Answered on Apr 29, 2021
Could be bad LED's in the panel, the driver circuitry senses current use by the LED's and if it's out of spec due to a faulty LED it will either not allow the backlights to come on or they may cycle & blink it also could be a fault in the driver circuitry but it seems that there has been a high LED failure rate. I would suggest that no one operates their tv as it comes out of the box (default settings) go into the menu and adjust the brightness down a little that will put less stress on the LED's.
The problem is either the color wheel or dmd board. Both parts are expensive so I would recommend contacting a Samsung authorized repair center. You can call 1-800-samsung or go to samsung-usa.com to find a service provider.
Samsung... • Answered on Apr 26, 2021
then the backlights have a problem
try looking in the main menu
Samsung... • Answered on Apr 25, 2021
Cable connection problem: Your Samsung Smart TV is likely to have a black screen issue due to the cable connection problem. Loose connections, damaged cables or inactive power sources are the probable cause of the problem on your TV. ... If the menu appears on the screen of your TV, then the problem is with the sources.
Samsung... • Answered on Apr 24, 2021
Samsung SV-DVD3E DVD Player/VCR Logo
19 questions posted
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
am looking circuit diagram samsung
  • Televison & Video
