Laptop cannot acquire ip address from router even though cable are connected.my router is WRT 120N Linksys. it is already set to get ip address automatically. it ends up having no connectivity. i have reset the router already. i haven't accessed it even once.
HERE. look on page 17 of the .PDF, it shows you how to block web addresses and other types of traffic. Its under chapter 2 Access Restrictions > Internet Access
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data. then do this : 1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable. 2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router. 3. Type http://192.168.1.1 in the address bar of your web browser. 4. Log-on to the Linksys WRT-150N Router with these log-on credentials: Username: linksys (lower-case) Password: admin (lower-case) 5. Click on the "Clone PC MAC Address" tab. 6. Click the "Clone PC MAC Address" button. 7. Click "Save", click "Continue". 8. Click the "Wireless Security" tab. 9. Choose "WPA2 Personal - TKIP/AES" for encrypted security. 10. Enter encryption password (passphrase). 11. Click "Save", click "Continue". 12. Exit the web browser. 13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router. In about 5 seconds, your wireless connection should be up and running.
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data. Then do this 1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte) 2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router. 3. Type http://192.168.1.1 in the address bar of your web browser. 4. Log-on to the Linksys WRT-160N Router with these log-on credentials: Username: linksys (lower-case) Password: admin (lower-case) 5. Click on the "Clone PC MAC Address" tab. 6. Click the "Clone PC MAC Address" button. 7. Click "Save", click "Continue". 8. Click the "Wireless Security" tab. 9. Choose "WPA2 Personal - TKIP/AES" for encrypted security. 10. Enter encryption password (passphrase). 11. Click "Save", click "Continue". 12. Exit the web browser. 13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router. In about 5 seconds, your wireless connection should be up and running.
Check your computer's browser settings, make sure it's getting valid IP address, try pinging a website and check your IP settings under network connections.
Disable any third party firewall software you have installed.
Sometimes you have to change your computer's settings or the routers settings to know what type of encryption its looking for otherwise it will just stay on acquiring.
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router 2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Please check if the router needed IP address? - if yes? ( goto Network Settings and add the IP address. - if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1.
Log on to the client computer as Administrator or as Owner.
2.
Click Start, and then click Control Panel.
3.
Click Network and Internet Connections.
4.
Click Network Connections.
5.
Right-click Wireless Network Connection, and then click Properties.
6.
Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties.
7.
In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2 Subnet mask 255.255.255.0 Default gateway 192.168.0.1
If you care to try, manually enter IP settings in your laptop as follows: IP Address - 192.168.1.2 Subnet Mask - 255.255.255.0 Default Gateway - 192.168.1.1 DNS - whatever your ISP is using
In your Internet Explorer > Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically.
You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc.
Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
What version of windows are you using?
