Watching my tv last night there was a slight popping noise from it then the picture went blank. The sound works but I have no display. Any Ideas ? 42inch LG Plasma
Check the power board for any domed capacitors. Replace them. If this does not fix Replace the power board. You can check the voltages from the power board. they are labeled. VS and VA voltages are the panel voltages.
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
