Expert
- Posted on Mar 18, 2010
Re: It wont take pictures
Determine how the camcorder works. There are 3 basic modes of capturing stills with a camcorder. Read your instruction manual for specific information.
Step 2
Understand freeze-frame stills. The most common and least effective method is a "photo mode." Basically, the camcorder will simply freeze a frame of video for a few seconds, which can then be extracted later as a still.
Step 3
Use editing software to capture stills. This method is similar to the first, and can be done with any camcorder. Download an editing program or use the camcorder's bundled software. Then transfer the video over to your computer and use the software to pull out stills.
Step 4
Understand built-in digital cameras. This is a more expensive option, but results in higher quality photos. These cameras have built-in memory cards and function basically the same as a stand-alone digital camera. Refer to the manual to switch over to digital camera mode, then point and shoot. The photo quality is usually a bit lower than from a stand-alone camera.
Step 5
Compare specifications. Understand that specifications for high quality video don't necessarily translate to high quality stills. CCD determines the quality of video, while megapixels determine the quality of stills.
Step 6
Consider the value. Whether or not a combination digital camera and camcorder is best for you depends on how you'll be sharing your photos
