KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen Aid Manual for RRK90 mixer I need one
I need a copy of the manual for a Kitchen Aid Mixer Model No. RRK90
  • Anonymous Mar 14, 2014
    I am looking for a part for my kitchen aid model #RRK90 serial # wm2813048 and Rpr 000721052 ultra power I need knob or leaver and how old is it ...
duceolsen
Level 2:
  • Expert 56 Answers
  • Posted on Mar 16, 2010
duceolsen
Expert
Level 2:
Answers
56
Questions
0
Helped
14163
Points
162
Http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
I have a Hobart kitchen aid mixer and I need a Manuel for it.
Hello, Fran -
The Whirlpool Corporation purchased the Hobart Kitchen Aid manufacturing unit in 1985.
I suggest you contact the Whirlpool Corp. directly and ask about the availability of a copy of a user manual for your model of Hobart mixers. Whirlpool probably took over the Hobart Kitchen Aid archival records. With luck the manual you need is still in the company archives.
This is the link to the Whirlpool Corp. Contact Us page:
https://www.whirlpool.com/services/contact-us.html
Best wishes.
1helpful
Kitchen aid mixer kg25hoxer repair manual
Manuals Literature
Kitchen Aid manuals link above
Sears link to manual below (may want to simply search with Google.com using the model name and number for parts if you plan to repair it yourself.)
KP26M1XSL5 KITCHENAID 6 QT STAND MIXER PROFESSIONAL 600 BOWL LIFT Manual...
Feb 26, 2018 • Food Mixers
Kitchen Aid model KUDSO1FLWH3
This is the food mixer part of the Fixya forums, you probably need to be in the dishwasher forum don't you? That's not a mixer model number that I'm familiar with.
Aug 28, 2014 • Food Mixers
Why kitchen aid mixer wont turn on
Any number of reasons such as:
Bad electric cord
Bad brush or brushes
Bad armature or stator
Control plate broken
You need the Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
While this manual does not cover the Artisan specifically, the procedures do apply.
Why is my kitchen aid mixers so Loud?
Could be,among other things:
Very worn brushes (although, in this case, the mixer usually stops entirely).
Worn gear(s).
Grease congealed and not lubricating correctly.
In any case, see the Service Manual at:
1helpful
1helpful
No problem just need a manual for all the parts of a K5ss mixer
Hi AUER24, you can easily download both the Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
This particular manual provides both domestic US and International Part numbers, which you will want to use, based upon your 220 volts rating that tells me you have an international model.
For future reference, here are five potential USA vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Also, here are some links to three excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
My wifes Kitchen Aid ksmc50 (rrk90) mixer leaks grease/oil from the rotating plate that the beater/dough hook attatches to.The grease/oil leakes from around the outer edge of the plate as well as from...
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
