Linksys WRT160N Wireless Router  Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Router connection Hello Why when I connect the router I fail to connect the internet, and I also fail to enter the default address 192.168.1.1 to make a setup for wireless connection. when I used command prompt ipconfig/all I received this page Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Julian>ipconfig Windows IP Configuration Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : IP Address. . . . . . . . . . . . : 10.0.0.9 Subnet Mask . . . . . . . . . . . : 255.0.0.0 Default Gateway . . . . . . . . . : 10.0.0.138 C:\Documents and Settings\Julian>ipconfig/all Windows IP Configuration Host Name . . . . . . . . . . . . : user Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Broadcast IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : Yes Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth ernet NIC Physical Address. . . . . . . . . : 00-13-8F-83-D1-98 Dhcp Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 10.0.0.9 Subnet Mask . . . . . . . . . . . : 255.0.0.0 Default Gateway . . . . . . . . . : 10.0.0.138 DNS Servers . . . . . . . . . . . : 194.158.37.196 194.158.37.211 C:\Documents and Settings\Julian> any one helpme solve the problem or give me a clue how can I make it thanks in advance My cable connection is from WAN port to the modem port, and from LAN of the router to the modem port Add a reply
Anonymous
Level 2:
New Friend:
  • Expert 137 Answers
  • Posted on Mar 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
137
Questions
0
Helped
35493
Points
229
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
I have a full signal on my pc via DIR-412 but no internet connection
Is this the first time you set your router? Make sure that the cable from your modem to your router is connected properly. You can also try connecting the modem directly into your PC just to make sure your modem is connected to the internet. If it is working without the router, reset your router then connect the modem again to your router.
3answers
Hi, I have a DSL-504T ADSL router that has been running without any problems for some time. I just bought a wireless Dl-624S router. I have been unable to connect the wireless router to my ADSL router.I...
Freind,
You should have a look on manual, if you don't have just goto the manufacturer's site and download a manual for your product.
I think it will help you in a better ways.
Thanks
Iqbal
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Hello I have a netgear wireless router WGR614 V5 which is connected to a cable modem and since several weeks I have many unexpected and random disconnection. So I must turn off my wireless router and...
HELLO,
Why are you using two routers,these might be conflicting with each other? Somtimes the drivers need updating.Try this first,and if this fails,disconnect the cable modem and just connect the wireless router to the main phone line socket via a modem filter and connecting a wireless adapter to your pc and install the driver for this adapter.The signal from the phone socket connection to the wireless router situated close to the main phone socket.Then connect the adapter to the usb port on your PC,and let the driver software and PC do the rest.That's all I've got on my PC.
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Hi, We have SKY Broadband connection at home and we use lapops with wireless connection in different parts of the house, the connection is very intermittent, keep loosing connection every few minutes. Can...
Hello.
If you have a router, check the physical connections to the router and reset the router. If still a problem, the router could be faulty.
Contact Sky Broadband for them to check their connection.
Hope this helps.
1helpful
2answers
Can't connect a laptop wireless to WRT150N
What you can do is remove the wireless connection profile that is saved and create a new one. Go to wireless connection properties and create a new wireless profile. If that doesn't work, what you can try is change the wireless channel of your router to Standard Mode using channel 11 the power cycle the router.
MTNL INTERNET PROBLEM
Hello.
Since your ISP provided you a username and password when connecting to a broadband connection, you have to setup the router's "Internet Connection Type" to PPPoE then you need to enter the username and password that you are using to connect to your broadband.
Once you do that, the router will obtain an IP address from your ISP(MTNL) then it will give connections to your computers
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
