Log in on router first you can change the acces for it.195.168.1.1 or 192.168.1.1 then go to wlan select the wifi protections setup and then go to w lan security fil in your code thad you want 64 bit 10 numbers
save every thing and then you have to put code for conection , you must remember the code
if you want to reset the modem on the back are small hole if you put pensil in it for severall sec the modem(router) will reset to fact defauld
Type in your ip address into the web browser, try 192.168.0.1 then type in your username and password (if required, located on your router) then it should take you to your network system settings, the rest of the set up depends on your routers brand, ie netgear, linksys..ect, just look for the security tab and it should be self explanatory... Hope this helps! good luck
