Arpanpallar, If you are certain that pc not causing problem, then hp internal "switch-mode-power-supply" could be the problem. Noisey DC source will cause very strange things to occur on screen!! You or technician will need to look for common visual signs of bad capacitors on the circuit board. Do some reading in my and other CCFL back-lit lcd monitor tech's fixya profiles. 12fixlouie
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
