Hi, By the information you've supplied, I'd guess you burnt out the coil in the water/fill valve by running it without a water supply to the valve. Are there any other unusual symptom's or error codes ? i.e. drain pump running none stop ? Can you put water into the tub manually and run a rinse cycle without issue ? In any event the valve is pretty inexpensive, usually about $30 or so. The part # 425458 works on all bosch, thermador, gaggenau, and siemens dishwasher built since the early to mid 90's up to present day. Hope this was helpful to you. Thanks for visiting "fixya" today. Good luck. macmarkus :)
