Bunn VPR Coffee Maker Logo
Posted on Mar 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BUNN VPR commercial coffee pot, not flowing in a steady stream just dripping
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262655
Points
1837
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
Anonymous
Level 1:
Scholar:
  • Contributor 40 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
Scholar:
Answers
40
Questions
Helped
32883
Points
76
The unit may simply need to be decalcified. You may need to use a toothpick to remove blockages in the spray head, and there may be a flexible wire to assist in removing blockages behind the spray head leading to the tank (refer to owner's guide). If these measures fail it may be a problem with the thermostat/electrical system. For support go to:
http://www.bunnomatic.com
Water leaks from the top of the right side of commercial coffee maker
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
How do I get the BUNN VPR coffee maker to brew a pot of coffee? There are two switches; one for the lower, and one for the upper warmer. Do I first have to fill the tank ALL the way before it brews? Please...
This brewer has a 2 1/2 pot reservoir. You should NOT plug in the brewer before the reservoir has been topped off. Pour 3 pots (one at a time, every minute or so) through the screen with a pot under the filter basket. Wait until the water flows from the basket and only then is it safe to plug in the brewer. The reservoir holds HOT water until you are ready to brew and then, by pouring in a pot of cold water, you will be able to brew.
3helpful
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
4helpful
What is the best way to remove lime scale and other mineral build up from a Bunn VPR coffee maker? Water flow has been reduced to a trickle even though we used filtered water.
I always use CLR to clean my coffee maker. You don't need much more than 1/4 cup and mix with 8 cups of water and brew it like you would make a pot of coffee, then dump it out and run 2-3 more pots of just water, that should work fine. Also, run vinegar thru the machine once in awhile to help keep it clean
2helpful
2answers
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
1helpful
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Water coming out of everywhere from the sprayhead.
Not sure what the problem is here.
You want the water to come out of all the holes. that way it wets the coffee grounds completly.
Is it over flowing the brew funnel?
This is commercial and the water drips instead of flowing,took 20-30 min to make coffee, how can i clean?
Have you tried to brew without coffee to see how long it takes? If yes then use a pair of channel locke to remove sprayhead and then use the deliming sprding that came with your bunn and clean the brew line then try again, if you still get the ame result, the brewer needs to be descaled.
I own a bunn and my brother's business owns 2 of these. The rule of thumb as he was told by the salesman is 2 oz of coffee grinds per 48 oz of water.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
