Dishwashers Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher rinse aid doesn't dispense, glasses are spotty.
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Mar 03, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126692
Points
799
Ok here is the best i have on this matter.
your question should have included a model #/make,only so i can givealittle more info. whenever your dispenser is not working 9-times out of 10 the dispenser has tobe changed. on some models you can get a kit to recondition the dispenser ,but to me its always better to replace the dispenser. replaceing a dispenser is not that hard if you have the no how. the door panel has to come off and the dispeser in some cases has to be unplugged from the unit. the dispenser normally has tabs that has to be snapped in and snapped out. after the snaps push the dispenser in the opposite way to remove and when you change go in the other direction. 1 tip the gasket can be lubricated to snap in easier. once you snap in plug back up and rescrew the panelthat should do it . if you need to have it service you can go to searspartsdirect.comand see the image and order the part at this site. call ten tech and askthem whats the price on changing the dispenser only .who ever has the best price and seems like they know what they are doing go with them. if this helps. send me a 4 thumbs up post thanks !
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
1helpful
Cycle wash leaves marks on glasses
Is the rinse aid dispenser full? Then, you might need a better brand of rinse aid or detergent. Some lead crystal glasses can't be put in a dish washer but you have probably considered that.
Sep 06, 2015 • Dishwashers
The rinse aid dispenser is not adding any rinse aid. how do I unclog it so my drinking glasses don't come out feeling like they have sand all over them.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
GlassEs won't clean
Do you use a rinse aid? I've been using a orange grease cutting gelpacs in the soap dispenser and make sure to use a rinse aid in the section with the screw on top. I usually fill the rinse aid about once a month. The citrus gelpacs seem to make glass sparkle. I've only tried the "Finish" brand of gelpacs.
2answers
Ecomax 400 400-17 Glasswasher is not drying glasses completely. Streaks left on glasses
It sounds like the rinse aid has run out or is not dispensing. streaks on glassware is the usual symptom of this. Check and refil the dispenser. On the final rinse, open the door and you should see soap foam , which will let you know the rinse aid has ejected, or alternatively, if you havent had to fill the dispenser in a long time, I would say its not ejecting. these are not usually repairable and you will have to purchase a new rinse aid dispenser from the manufacturer. I always suggest usung " finish" rinse aid, its the best.
1helpful
LG Inverter Direct Drive, at the end of the cycle there is a grey -white residue on everything, interior,glasses,pots n pans. We use Cascade packets and Rinse-aid. Please help!!
The packets usually have detergent and rinse aid together, built in. If you also have liquid rinse aid in the automatic dispenser, you are getting a double dose, and that is causing the film. Use standard dishwasher detergent until the automatic rinse aid dispenser is empty, or at least turn the pointer indicator (located by the rinse agent filler) to the lowest setting possible to help somewhat.
Jet dry dispenser doesn't work, gets spots on
If you are going to do the job, order part from searspartsdirect.com . they will give you the image, part # and the price. the door panel comes off and and the dispenser snaps in with tabs that you have to pry up and push either out or in. unplug dispenser and make sure you lubricate dispenser gasket. then reinstall by pushing in and listen for the snaps as you push in. re connect the plug put on panel and re screw panel if you want a service guy to replace tell him you only want a dispenser changed and how much willyou charge,if you ask 10 tech you will get prices .choose the most experienced and cheapest.
Mar 03, 2010 • Dishwashers
2answers
Spotty, filmy glasses
Even if you are sending it 120 degree water from your hot water heater, if the internal heating element has failed, your will get poor cleaning, including a film on your glassware.
Replacing the heating element will almost certainly fix the problem.
Good Luck!
Rinse solution stays on the glasses
First chech the machine is warming the rinse water and not rinsing in cold water then have your chemical guy come and check that the soap/rinse ad dispenser is not dispensing too much rinse aid and naturally make sure the machine is in fact ricing with water I have had it where a glass washer takes more rinse aid then i should and does not actually rinse with clean watr it was simply spraying the rinse aid wich sounded as if it was rinsing soulution was new pc board it was not changeing programs properly if you have and older machine it proberly has a timer this too can be a cuase of the problm if it is not clicking over to allow a full rinse cycle.Hope this helps let us know.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
