Check the disc. The disc could be full or the disc could be the wrong format. The disc could have smudges on the back of it. Clean the disc. Remember, DVD -R can only be recorded one time. If you mess up, you can not record on it again. Once a DVD-R comes out of the tray, it is automatically finalized. You can not add to it. I recommend using DVD+RW. It is user friendly disc.
Hi
This could a dirty lazer bulb try cleaning with a damp shammy leather allow to dry for a few min's . if this does not clear fauly lazer unit will need replacing
regards windyhouse
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs.
Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd
"e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder?
Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Bulk disc that comes in cylinder case are some time faulty and loses quality because they packed on each other. The lens of the disc are sensitive so if disc is scratch or dirty will get error message "no read". Turn the unit off then unplug ac power cord for more than two minutes then reconnect and try disc again, if issue still exist purchase disc that comes in individual case.
Try to use a cotton swap to 1st clean the recording lens or blow gently
on it. Place an empty disc in, format the disc, record a little scene.
Turn off camcorder. Place the error disc in the camcorder, turn on the
camcorder all the way to play/edit. If this doesn't work turn it to
record and try to record. Worked for some of my error disc
what make of disc are you trying to use
