Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
Posted on Feb 23, 2010
Pop off valve dripping Rheem 50 gal electric valve at bottom
What causes a dripping leak at pop off valve at bottom of Rheem electric 50 gall.
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
18992
Points
62
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Vacuum valve is leaking/dripping.
If you are talking the P&T valve, then yes...about 10 dollars @ the hardware store. You may want to think about an extrol expansion tank if your city water give you pressure problems.
Rheem marathon vacuum valve
Copy following link for Rheem marathon parts and resources:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Add a comment March 2013 and describe problem in detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem Marathon Water Heater leak at pressure relief valve
Unless you are getting more than 150 PSI, you should just replace the valve. It has dirt in it.
1helpful
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
How to turn off water heater it is leaking all over the floor
There should be a valve on the water supply line just above the water heater. There may just be a drain spicket located at the bottom of the water heater that is leaking. You may just be able to put a cap on it or try to turn it tighter to stop leaking.
2helpful
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
I own a Rheem Power Vent with powerglo ignition system - model # 21 vp50-1 50 gal, serial # rn 089d06577 ---i've noticed water on the floor around the water heater, i thought maybe the tank was rusting out...
The plastic drain valve is a possibility. Also the Temperature/pressure relief valve is typically piped close to the floor if there is a drain near by. People tend to ignore water heaters. The TPR valve really should be excersized annually. If it won't re-seat, then it should be replaced. Second the tank should be partially drained annually to drain any solids that have accumulated in the bottom over time. If you don't do this frequently the drain valve can become almost impossible to operate.
1helpful
Water on flour of water heater
If your water tank is leaking, is it dripping from above or actually leaking thru the bottom?. Can you find the source? Feel around and try to find wet spots above and around it. If it's not leaking from the water pipes or T&P valve, it's your tank leaking. You'd be wise to have it checked out in the morning, before it gets worse. Hopefully your catch pan has a pipe attached to divert water to the outside or to a sump pump or floor drain. Water heaters do sweat, but you can tell the difference if it continues to leak for several hours.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
