4gb pny thumb drive ask to be formated evertime i put it in my vista computer. It is used on a vista computer and snow leapord primarily.
My wife formated it. Is it possible to recover the data?
Don't worry! As long as you take the right steps, you absolutely can restore all your lost data back:
1). Do not add any new file on this memory card in case that anything new would rewrite your original data.
2). Insert this card to your computer and prepare to restore the data.
3). Do not randomly select a data recovery program. In your case, an efficient data recovery program always means a lot. Therefore, you can try to apply a formatted memory card data recovery freeware to get back your player data successfully:
http://www.freeware-fix.blogspot.com/2013/03/memory-card-recovery.html
4). Do not save the restored data on the same card in case of data recovery failure.
Note: Never try to save everything important on only one hard drive or memory card next time.
Hello
My
apologies if this message finds you long after posting this problem ,
but I am currently working through a backlog of problems that never got
answered and hopefully this info can still be of use if not now possibly
in future.
Please download Disc Digger HERE.
This is a free tool you can use that works very well and there is no
installation required, just run the program once you downloaded it.
Once
you have connected the memory disk / hdd to the computer , run the program.
On
the program , select the dig deep option for accidentally deleted files
or dig deeper for a formatted drive. Then select the disk you want to do
the recovery on and run the program.
The data will be displayed
and you can recover it from there. This will only work if the card has
not been used since the data was lost. Save the files to a location
on the computer hard drive and not back to the disk it is recovering from as this will
overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
