I can't find your models breakdown but it sound like a bad motor. if it drains and fills you have a good pump. if you had just a bad motor control if mostly would agitate. If the motor hums then you are getting power to it.. if you have no hum you can check for power with a meter.. if no power you have a bad control.. if you have power you have a bad motor... let me know what yo find out.. krazytech
If the drum is also loose, it is dead. The plastic your are finding comes from a part inside. It will cost more (or close) to fix than to replace and you risk breaking other critical parts if you DYI.
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
