It seems flexible ribbon wire between lcd board and camcorder main board is cracked/ broken and causing this problem, you need to replace that flexible ribbon wire and it is job of qualified camera tech because camcorder will take apart in this process.
Nearest Panasonic service center or local camera repair shop would be fine to get camera fixed.
Hope this info will help you.
Thanks.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
