JVC GR-DVL820U Mini DV Digital Camcorder Logo
Question about JVC GR-DVL820U Mini DV Digital Camcorder
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Posted by shahid_za23 on
Anonymous
    Guru:
  • 592 Answers
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Posted on Mar 02, 2011
3answers
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
2helpful
The camcorder has only been used 3 time we got it out and the screen is black the lense cover is off we can watch previous stuff on the screen but when trying to film it remains black and records black...
The problem is that the ccd ic has gone out or the lens has failed causing the iris to stay closed. It is experience with that camcorder that the ccd assy is the culprit. I hope that helps.
I have a JVC video camera modelGR-D290U. I can play and view tapes previously recorded.But when loading a new blank tape the screen does not show what is being recorded and remains blank when rewinding and...
Sounds as though the imager may have failed but make sure you are in video postion instead of memory mode. Little switch behind the lcd screen. Larry's Electronics
Panasonic NV-GS40
the possible fault may be bad image senser CCD. you require a professionl to change the CCD.
1helpful
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
