This PC was sold new day1, in 2009 (a bad year)
and as such had (per your manual) has toxic mercury CCFL background tube lamps at the LCD screen that do just exactly as told so very well.
and PC means
Personal Computer
and CPU means central processing unit, a chip a USA invention !
when the screen is black we use the flashlight test (uk torch , burn free, lol.)
point it here.
see data the CCFL? yes, are dead and the do fail intermittent or by hot and cold room. or dead or dim or got yellow for white tinged.
the problem is bad hardware and googling finds endless geeks that do not understand hardware at all, or little (i call em bit flippers)
Too bad all makers of PC and monitors did not put screen test mode button on the PC, that glows the back lamps
in our shop we use HV CCFL tester to find that truth easy.
the monitor is bad on the desktop PC
if you test the monitor on 2nd PC it fails
if you the failing PC with known good monitor the PC passes all test.
now you learn 3 simple tests, of vast.
but in order based on AGE
big clue #2 is monitor newer showed its ERROR NO SIGNAL or NO connection error, so that clue means PC did not die the monitor did.
no signal , no connection, no sync, or over-range errors never seen.
fans normal. blowing. in PC is clue 3 (and all LED you told too)
Sounds like the VGA lead that connects your monitor to PC is either faulty or not plugged in correctly.Make sure it is tightly connected at the computer.Ive had this problem a few times, from the fault you have described to flickering xolours on picture..gently wiggle VGA lead socket at computer.Does picture come back on? Maybe your PC video card is not pushed into the motherboard enough?
