20 Most Recent
BenQ FP92G+S (Black,Sylver) (Silver, Black) 19" Monitor Questions & Answers
Benq FP92G screen blank, power
More likely to have power supply problem, that will be the first place to check, look to see if it has any caps with leaking/bulging tops/seal, burnt spots, shorted transistors in the backlight inverter board, cold solder joints. Look at my DELL albums (BenQ made a lot of monitors for DELL). Be real careful when removing the front bezel, you can easily rip apart the cable.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Benq fp73g s wont turno on ,
The problem is in the power supply board there is one or two capacitors that open, in some cases it will have slight puff at the top.
3/16/2012 7:01:27 PM •
BenQ FP...
Answered
on Mar 16, 2012
Repair power button BENQ G2400WD
It is possible to bridge to another power supply. There are simple tutorials on YT to help and the process is not very invasive, if you do not wish to harm the current bezel. I was unable to find a switch online to match the model number. Maybe try something close enough to match.
