WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
You most likely blew out your power supply but may have damaged other components as well. The power supply converts the AC input to lower DC voltages used by integrated electronics. Even powered down the fax has a
circuit that supplies voltage to the internal battery and volatile memory components, Called VSB for "standby voltage" even
when it is officially "off", a surge can pass through the power supply and one fried move freely into the system to damage the internal components.
You will not be able to print out these fax's until the machine is fixed. There is no way to transfer them to another machine, but they will still be there after the repair is done, provided the tech doesn't reset your memory. Which hopefully, he won't since he has no reason to do so.
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
I have not worked on a sharp ux-117 before, however most sharp fax machines are all alike when it comes to resetting this code. Turn the fax on while holding down the stop and start key don't let go until you see 1 =yes, 2=no for memory clear. press 1=yes. Some of the sharp fax machines have a small white rounded reset button. No guarantee but you have nothing to lose.
I have a sharp UP600 which is used in our off sales (vendor). One of the fellas punched in 5050 @ singles empties returned instead of 50 @ single empties returned. I now have 5000 empties returned to many. How can I fix this mistake?
