My Kitchenaid mixer (k5ss lift bowl?) smells as soon as I start using it. It makes an intermittent noise at lower speeds, best described as a groan or low pitch squeal. There is no noise at higher speeds.
What should I look into for repair?
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
