SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
SOURCE: dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water
shut-off valve (located under the sink) is open. If you get water to
the dishwasher, but there is still no water inside during the fill
cycle, the problem might be with a faulty water valve (located at
the bottom of the dishwasher, behind the kick panel, on either
side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This
could be caused by a partially closed water shut-off valve (located
under the sink), or a faulty dishwasher water valve (located at the
bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher.
Make sure there is no debris blocking the holes inside each spray
arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees
Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to
both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the
dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
SOURCE: top rack washer arm isn't spinning and therefore
You can replace the whole top assembly. And before you run the cycles again, try putting a cup of Tang (dry) orange juice through the cycle without any dishes or get some Dishwasher Magic and you'll have a sparkling new dishwasher once again! hope this helps you!
