It would have helped if you provide the Dishwasher model.
HOwever, I am assuming you have the power connected and inlet water is turned on.
It is likely the child control button might be enabled. CHeck dishwasher manual to show how to disable child lock.
If this is not the problem, then assuming your dishwasher has this feature, try to hard reset the dishwasher to factory setting. This is usually done by pressing 2 buttons (depending on dishwasher) together for a specific time. Or in some cases the mains power is turned off and on within a specific time.
Please post a comment to indicate your observations and model no. Please do not rate this solution until I have got some more details of your dishwasher problem.
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
