20 Most Recent GE GDWT166VSS Built In Dishwashers Questions & Answers
remove and clean pump
GE Dishwashers | Answered on Mar 26, 2020
There is a pan under the base of the machine with a sensor in it. You have a leak, but you can't see it because it is in the pan.
E4 means that the dishwasher thinks there is water below the tub in the base pan. Make sure you don't have a leak from one of your hose connections and if that all checks good, call warranty since the unit is brand new because either your control board is bad or there is a leak from the factory if it is in warranty.
GE Dishwashers | Answered on Feb 14, 2020
Does it cycle i.e. fill, wash, rinse, and drain?
If yes, then heater relay likely has failed (closed).
What model number?
GE Dishwashers | Answered on Jan 18, 2020
Sooo with my model just for anyone looking this up. My son loves pushing buttons and one of his favorite is the “delayed start” button. After researching, cleaning out the filter, unplugging the dishwasher and most everything short of pulling my hair out, I found out that the little nugget had pressed the delayed wash button. Which, you would think would reset when you reset the machine but evidently not. Pushed the delayed start button and cycled through 12 hrs and bingo, it ran....
Not a fun way to spend the night but at least I saved money by not having to call out a repair man. ??
GE Dishwashers | Answered on Dec 30, 2019
sorry we can not call the manufacturer as brand new should be under warranty
GE Dishwashers | Answered on Dec 13, 2019
The cycle timer may have "hung up".
GE Dishwashers | Answered on Dec 11, 2019
The one way flapper in the drain pump has broken off.
GE Dishwashers | Answered on Dec 05, 2019
Did you install it, or did the vendor install it?
If it is brand new, contact the vendor for assistance or replacement under warranty
GE Dishwashers | Answered on Nov 13, 2019
Shut off power to dishwasher at electric panel,shut off water supply,open door of dishwasher,remove screws on top side of dishwasher that are screwed into the underside of the countertop,,remove the front service panel on the bottom front face of the appliance by removing two or more screws on the right and left,locate and disconnect the water supply feed,locate and disconnect the electricity supply cable,locate and disconnect the drain hose usually connected to the drain of a nearby sink,pull dishwasher out of cavity in cabinet by grasping both sides of dishwasher with door slightly open,adjustment of front legs of appliance may be necessary.
GE Dishwashers | Answered on Nov 10, 2019
E4 means dishwasher sensor is detecting the dishwasher is over filling. First thing I would check is the float. You will want to make sure it travels up and down freely. Open your dishwasher door all the way. Look on the right hand side (could be in a different location on your model) you will see a round thing. Kind of looks like a air hockey pusher. Try moving it slowly up and down making sure it’s not stuck open.
If this didn’t work then I would lean towards a faulty sensor.
It’s possible you could have a faulty board as well.
It is my opinion unplugging it will have no effect on this particular issue.
I hope this information has helped. God bless and have a great day.
GE Dishwashers | Answered on Nov 06, 2019
I DON'T KNOW. INSPECT CHECK FUSES OR CIRCUIT BREAKERS. BE CAREFUL AND MEASURE FOR ELECTRICITY AT WALL RECEPTACLE.
GE Dishwashers | Answered on Nov 03, 2019
GE GDWT166VSS Built In Dishwashers Logo
1 questions posted
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
uninstalling ge potscrubber 900
  • Dishwashers
