Hi
Thanks for using FixYa.F9 is a door latch error,
you’ll need to check the door latch. This is a Problem with door lock circuit
such as pinched wire between Electronic Range Control (ERC) and door lock
switch. You’ll need to check wiring and replace the door latch assembly if
required.
Please do accept the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: code f9 on frigidaire self cleaning oven. what
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Hi
F9 is a door lock error and to solve this issue you can hold
the light switch for 15 seconds, this will reset the control. If it won't work
then hold the light switch in and set the unit to clean and after a minute
press cancel to cancel the clean cycle. If still it won't work then the door
lock assembly should be replaced. Hope this helps...please post
back for further assistance.
Daniel
Hi
Daniel
f9 will not reset
