Amana AOCS3040SS Electric Single Oven Logo
Posted on Aug 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 07, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232910
Points
12714
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 05, 2013 • Ovens
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
Oct 25, 2011 • Ovens
1helpful
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
Daniel
1helpful
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
7helpful
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
Dec 18, 2009 • Ovens
2answers
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Thanks.
2answers
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Top Amana Ovens Experts
ADMIN Andrew
ADMIN Andrew
Are you an Amana Oven Expert? Answer questions, earn points and help others
