20 Most Recent Kenmore 47702 / 47704 / 47709 Electric Single Oven Questions & Answers
Broiler won't work
the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
4/10/2015 5:29:01 PM • Kenmore 47702 /... • Answered on Apr 10, 2015
Half of the element of my range stopped working. How to diagnose or fix a short-circuit?
OK 1 D/C the power to stove. 2 get an olms meter and remove the burners, 3 Put one test wire on the wire to elements wiring other end to plug. . turn on burner switch and see if you get 0 ohms reading if so good cercert. if not bad. move the test lead to each of the 3 plug prongs. before you move to the next wire to the element./ You trace them all you will find your short. also inspect all wire for brakes that could be touching metal. Hope this helps mike
11/20/2014 12:40:40 AM • Kenmore 47702 /... • Answered on Nov 20, 2014
CORRECTVOLTAGE AT BAKE COIL WITH OVEN ON
The nominal 240 volt oven should be 240 volts or very close to it.
5/10/2014 3:56:16 AM • Kenmore 47702 /... • Answered on May 10, 2014
2answers
SHOULD BAKE ELEMENT GET RED
Yes. It gets red when it is heating; it'll go on and off to maintain oven temp. If it doesn't work at all it could be loose, burned out, to other electrical problem.
4/29/2014 5:38:34 AM • Kenmore 47702 /... • Answered on Apr 29, 2014
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
2/5/2013 12:46:08 PM • Kenmore 47702 /... • Answered on Feb 05, 2013
2answers
Replaced Bake Element (WB44T10003) on
Hi
Thanks for using FixYa. As everything is working fine so the issue is with the oven temp. sensor (probe)going bad and should be replaced. Hope you understand that both bake and broil element wont go bad at the same time. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
11/18/2011 7:07:42 AM • Kenmore 47702 /... • Answered on Nov 18, 2011
The letter and numbers f10 keeps appearing on my
0Hello,
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
9/9/2011 9:44:53 PM • Kenmore 47702 /... • Answered on Sep 09, 2011
How can i ligh pilot on of kenmore oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
6/29/2011 2:53:22 AM • Kenmore 47702 /... • Answered on Jun 29, 2011
I have a kenmore elite
http://applianceguru.com/forum1/13.html Hi, this will give you some idea where to look.
Good luck.
6/20/2011 7:40:14 PM • Kenmore 47702 /... • Answered on Jun 20, 2011
Alarm comes on and display
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
4/11/2011 7:11:22 PM • Kenmore 47702 /... • Answered on Apr 11, 2011
E1 F3 error code
F3
- E1 Oven temperature sensor (RTD) shorted
(upper oven, if double oven)
Replace
Note: Applies to all
F3-E... codes
2/23/2011 5:12:14 PM • Kenmore 47702 /... • Answered on Feb 23, 2011
Touchpad not responding but can
Hi
The touchpad is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
1/31/2011 7:13:47 PM • Kenmore 47702 /... • Answered on Jan 31, 2011
Locked door light flashing
I had the same problem with a gas kenmore oven. I played with the lock mechanism (opened it a little more manually) and it fixed the problem...
1/10/2011 8:20:15 PM • Kenmore 47702 /... • Answered on Jan 10, 2011
Oven displaying code F1
Sorry to read about your problem.
Try this to determine which part is needed.
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
I tried to help you.Please help ma and rate/vote this response. Thanks and good luck
1/3/2011 4:50:36 PM • Kenmore 47702 /... • Answered on Jan 03, 2011
2answers
I have a Kenmore 790.95660100 and the stove will
Sorry to read about your problem, I hope this helps you out.
you may have a defective temperature probe.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/23/2010 11:09:17 PM • Kenmore 47702 /... • Answered on Dec 23, 2010
E0-F2- what does that mean
Hi, you have a keypad problem here. First try pressing the cancel/off button for 5 seconds. If the code is still there, disconnect the power for about a minute and connect. If the error returns you will have to get someone to disconnect the keypad ribbon cable from the main board, clean the end with an eraser and re-connect it. Re-apply the power and see if the error returns. If the error returns, probably a bad keypad. E0-F2= stuck or shorted keypad....
11/8/2010 4:22:13 AM • Kenmore 47702 /... • Answered on Nov 08, 2010
Kenmore 47702 / 47704 / 47709 Electric Single Oven Logo
42 questions posted
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Ovens
  • Kenmore Ovens
Most Popular Question
half element range stopped working
  • Ovens
